Can someone please look at this image of router combo and identify the parts?
I bought this router combo locally, and later found out it is missing a couple parts that were not mentioned. I am unable to contact the original seller, and I am hoping this community can help me identify the parts.
I highlighted one part in blue, and one part in green. If you know what the missing parts are called, and what they are for please respond by listing which part you are talking about as either blue or green.
Thank you!
Thank you!
Well...blue looks like an edge guide (not sure if that's the correct name), the green may be a vacuum attachment....but since it's a very good brand...you should be able to go to their site and look up parts.
The t-handle looks like a collet height adjuster that maybe you would insert through a hole in the router base and would use when the router is mounted upside down in a table so that you could adjust the collet height from above the table rather than under.
Giving us a model number really would be helpful if you want a specific answer. I can make out "Milwaukee" but that's about it. I suppose we could search and try to figure it out, but...
Thanks for the responses!
It is a Milwaukee Model 5615-20 router, and it looks like the combo set featured in the link below!
Milwaukee 5615 84 Factory Recon 5615 24 1 3 4 Max HP Multi Base Router Kit | eBay
