Laminate Countertop Repair
Old 05-02-14, 03:17 AM
My wife set an about 6" diameter burning hot pan on the countertop and created a burn spot about 1/2-3/4" across, and another bubbled up area that when opened and sanded will be about the same. Any recommendations for fixing up these spots?
Old 05-02-14, 04:05 AM
chandler's Avatar
Received 3 Votes on 3 Posts
Welcome to the forums! Laminate is basically irrepaieable once it is damagedas you have described. About the only suggestion I would have is finding a Corningware type cutting board insert, remove the rubber feet and glue it to the smoothed out countertop. It will hide the ares, provide a permanent cutting board, and a permanent hot pad.
