How difficult is to wood fill the door jam hinge ?
Old 07-21-16, 03:04 PM
V
Hello would anyone tell me how easy or difficult is to fill the section of a previous door hinge with wood filler ? I want the fill to be near Name:  IMG-20160721-00334.jpg
Size:  15.9 KBperfect and then painted over.
Old 07-21-16, 03:13 PM
Received 427 Votes on 382 Posts
I'd take a paint stir stick and cut it to fit and then use filler around the perimeter.
Old 07-21-16, 06:07 PM
V
@marksr do you mean cut out a template which outlines the door hinge cut out as seen in the picture and then use it fill in the wooden hinge areas ?
Old 07-21-16, 06:14 PM
XSleeper's Avatar
Received 990 Votes on 901 Posts
Looks like a paper mdf jamb, not wood. You could probably just bondo it. Will take several coats and lots of sanding.
Old 07-21-16, 06:25 PM
Received 107 Votes on 94 Posts
I want it to be "near", near what?
What exactly is it your trying to do?
Old 07-21-16, 07:04 PM
XSleeper's Avatar
The "r" is next to the "t" on a keyboard. I think he meant "neat," not "near".
Old 07-21-16, 07:29 PM
V
@joe the OP was not properly completed if you look at the OP you'll see the words perfect and then painted over after the picture.
Old 07-21-16, 07:32 PM
XSleeper's Avatar
Ahhh, I missed "perfect and" way over there.
Old 07-22-16, 03:20 AM
Back when square corner hinges where the norm we would just cut the length on a stir stick and insert it where the hinge was which made an almost perfect patch, just had to fill the minor gap along the perimeter. Take a coping or jig saw and cut the radius, tack it in and then fill as needed.
Old 07-22-16, 04:08 AM
Norm201's Avatar
Received 372 Votes on 337 Posts
When I reversed the swing on a couple of doors years back, I just used wood filler. Stained it and put on ploy. Not noticeable unless you look at it carefully.
Old 07-22-16, 01:31 PM
V
@marksr now I understand about the paint stir stick but how can I keep the stir stick in place while bondo auto filler is applied over it ? Would I apply one layer within the areas of the hinge cut out first and then insert the stir stick piece of wood and then apply bondo filler around the seams and until the area is flush with the rest of the surface of the door jam.
Old 07-22-16, 02:24 PM
I'm not sure if the thickness of the hinge or stir stick has changed but all the times I've done it the stir stick was the same thickness as the hinge. Install the stir stick with a couple of tacks/brads. You should only need to fill the minor gap at the perimeter.
Old 07-22-16, 02:27 PM
XSleeper's Avatar
And coat it with wood glue before you tack it on. Let it dry an hour or two before you apply any bondo or wood filler around it.
Old 07-24-16, 07:56 PM
V
@XSleeper and @Marksr I just checked but the stir stick's thickness is thicker than the depth of of where the hinge used to be. Would cardboard work and if no than would anything else work ?
Old 07-24-16, 08:35 PM
Norm201's Avatar
No, you can't use cardboard. You could glue the stick and then sand it down. But as I said in my first post I just filled it with wood filler. Here are some pics of what I did. The first pic is the top hinge not fully stained. The second hinge is the bottom and fully stained. Its in a corner and cannot be sen very well.
top hinge: partially stained
Bottom hinge: fully stained
Edit: if you were to take the second pic and brighten it up and add a bit of contrast you will just barely see the outline of the old hinge.
Old 07-24-16, 11:22 PM
V
@Norm201 thanks. OK so wood filler should work alone without using any stir sticks and secondly I plan on painting over the wood filler with just latex paint with primer. Last question how can I put a barrier or some kind of edge to keep the filler within the areas of where the hinge used to be and while I'm trying to fill in the areas with wood filler ?
Old 07-25-16, 04:05 AM
Stir sticks used to be the same thickness as hinges.
To keep a straight edge with filler just use a stiff wide putty knife or most anything that you can set along the edge of the jamb to keep the filler straight.
A separate dedicated primer is best but you can probably get by with 2 coats of finish over that small area.
Old 07-25-16, 04:25 AM
Norm201's Avatar
Don't worry too much about the edge. You'll build it up and then sand it down.
Old 07-25-16, 05:08 AM
.... but the neater you can apply it, the less sanding needs to be done I hate unnecessary sanding
