Right size base cap moulding?
Is this the right size base cap moulding for 1x stock (e.g. 1x4)?
I assume I should be going by the total thickness (11/16") and then the "seat" of the base cap ends up recessed from the face of the square base moulding below. Is that right?
What do you do with the gap between the two pieces? Caulk it? Anything else I should know about installation? Thanks in advance!
