Install built-in cabinets / pantry over existing wall
Old 10-14-16, 10:46 AM
A
I am going to build and install built-in cabinetry to serve as a pantry. I already have a design, but am wondering if there's advice regarding wall preparation prior to attaching the carcass. It's currently a standard finished wall (paint over drywall). In the picture it is the setback where the hutch currently sits.
My plan right now is to remove the trim / baseboard material and attach my carcass supports directly through the existing wall into the studs, then refinish the corners at the top an bottom after completion.
Old 10-14-16, 10:56 AM
Received 315 Votes on 279 Posts
It's standard practice to install cabinets over drywall.
Not sure what you mean by that
Old 10-14-16, 11:27 AM
A
OK thanks. by refinishing the corners I meant that I expect to have to do some aesthetic work at each visible corner, so that the trim doesn't end or change abruptly.
Old 10-14-16, 04:35 PM
XSleeper's Avatar
Received 666 Votes on 616 Posts
A true "built in" would have a face frame that covers the corner bead and your baseboard would butt into it.
