Kitchen with pine finish painting?
Old 04-28-17, 05:04 PM
D
Hey guys
fairly new to this so please be gentle
Photos attached are of my kitchen, due to time constraints i am hoping to quickly face lift without sanding them right back or re-doing completely. Can anyone recommend any products/methods that can be applied without sanding back the existing coating?
Appreciate your help :-)Name:  20170428_174849.jpg
Old 04-29-17, 03:27 AM
Received 405 Votes on 361 Posts
Sanding is always best! Doesn't need to be sanded down to bare wood, just a scuff sand to give the primer good adhesion. You could wipe the cabinets down with a liquid deglosser and skip sanding [be sure to follow instructions] I normally do both. You'd then apply a solvent based primer followed by 2 coats of your choice of enamel; oil base, latex or waterborne [any sheen]
http://www.doityourself.com/forum/pa...t-repaint.html
btw - that's probably maple or birch, not pine
Old 05-01-17, 08:23 AM
Received 98 Votes on 86 Posts
I would give them a cleaning and a light scuff sanding followed by a couple coats of oil based polyurethane, which would darken them a bit.
Old 05-01-17, 09:20 AM
Unlike over raw wood, oil base poly won't deepen the color of the finished wood much. It will amber some over time.
