Damage to cabinet finish
Old 12-23-17, 08:40 AM
Marq1's Avatar
Received 505 Votes on 468 Posts
To me it looks like somebody had something scotch taped to the side of the cabinet, of course nobody has any idea.
It's pulled off the thin veneer and the substrate wood is exposed.
Luckily it's on the back side so not obvious, any method of repair?
https://www.doityourself.com/forum/a...1&d=1514047194
Old 12-23-17, 08:47 AM
Received 408 Votes on 364 Posts
Since it damaged the veneer, replacement is the obvious answer. If you are artistic you could probably fill the depression and faux paint the repair to match the surrounding veneer.
Old 12-23-17, 08:49 AM
W
Received 34 Votes on 31 Posts
Show a photo from farther back so we can see the face frame. I have an idea.
Old 12-23-17, 03:11 PM
Marq1's Avatar
Squint your eyes it came across blurred!
https://www.doityourself.com/forum/a...1&d=1514070658
Old 12-24-17, 02:29 PM
W
Order a matching end panel to cover the entire surface. The face frame will conceal the raw edge of the panel.
