Picture Window Molding
We're going to remove two double-hung sistered windows and replace them with a single picture window. It will be in the center of a wall of built-ins when done and below the window will be a box seat.
We don't see the need for a window stool and it will be a little uncomfortable if someone seated sat back against the wall.
I have no experience with picture windows. Are they normally trimmed with or without a stool? If so, I'm curious as to why?
Windows in general can be trimmed 3 ways. 1) Casing mitered at all 4 corners. 2) Casing mitered at top corners, stool and apron on the bottom. 3) no wood trim at all, just corner bead and drywall.
Nothing special about a picture window than any other window. Trim it however you like.
The harder the stool is the better equipped it is to resist moisture or other abuse. Usually if the window has drywalled returns they install a marble or tile stool.
