How to secure jar rack to wall?
Old 03-04-18, 05:51 AM
Q
Received 1 Upvote on 1 Post
I'm trying to make something like this to put mason jars on a wall rack.
what's the best way to secure it to the wall since there don't seem to be any mounting points on the back or side panels.
Old 03-04-18, 06:01 AM
Received 800 Upvotes on 703 Posts
You can drill thru the bottom cleat and screw it to studs. Add a cleat to the top shelf and do the same thing .... or add brackets.
Old 03-04-18, 06:17 AM
Q
L brackets?
just worried then that all the weight is supported by one cross shelf
if I put some sort of 1x ? Across the back flat then it will make the while rack stick out a bit from the wall.
Old 03-04-18, 06:39 AM
You could put a plywood back on it, secured to each shelf would give them a lot of strength.
Old 03-04-18, 08:24 AM
XSleeper's Avatar
Received 1,838 Upvotes on 1,654 Posts
Picture frame d rings.
https://www.amazon.com/dp/B00KZ83OZ0...a-432557612567
Putting a back on it might be a good idea too.
