Trim Advice
Old 08-16-19, 01:27 PM
C
Received 1 Vote on 1 Post
Trim Advice
We're looking for baseboard and door trim for our basement finishing project. We know that we want to paint the trim white.
Is it worth buying the pre-primed trim, or am I better off getting unfinished and priming myself? I've read some online stuff saying that pre-primed usually requires some additional priming anyway.
Also, we have kids, and I've read that MDF can dent easily. This being the case, I'm thinking I should be looking at at least pine. Does that sound correct, or is MDF not as fragile as I've been reading?
Thanks
Old 08-16-19, 02:04 PM
Received 321 Votes on 285 Posts
MDF paints beautifully but it is easier to damage and doesn't like getting wet. Pine would be more durable. Often the preprimed and unprimed are priced similar. For painted base/trim the finger joint trim is fine.
Old 08-16-19, 04:00 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
I would never use mdf in a basement. If it ever gets wet it's done for.
joecaption voted this post useful.
Old 08-16-19, 05:36 PM
Marq1's Avatar
Received 370 Votes on 345 Posts
I use MDF a lot for trim but it's always up at the ceiling where nobody can touch due to its low density.
Ive got a ton of MDF in the basement but as noted its up high.
