Contractor messed up skirting board
Old 09-22-19, 03:06 AM
T
Hi all,
Our contractor instead of removing old skirting board and putting laminate under the white skirting decided to save time and install a second skirting (see photos attached).
There's at least 2 problems with that for me:
1. it doesn't fit the laminate color
2. it takes extra space (half an inch)
Is there any way to fix this without huge time investment? Maybe a white angle skirting (like the one on the photo attached)?
Thank you
Top Answer
09-22-19, 03:51 AM
marksr
marksr is offline
Received 871 Upvotes on 762 Posts
While I prefer shoe mold that matches the baseboard I've done no small number of houses where they wanted it to match the floors. Floor finishers often stain it to match the floor because that's what they do [not painters] I also don't recall seeing cove molding used for shoe mold or quarter round.
IMO the tape wouldn't look good.
Old 09-22-19, 03:17 AM
T
Received 4 Upvotes on 4 Posts
It would typically be to match the baseboard, not the floor. Around here, quarter round or door stop moulding is the most common style. I have not seen that cove stuff used for that purpose before.
Teddbe voted this post useful.
Old 09-22-19, 03:51 AM
Teddbe, XSleeper voted this post useful.
Old 09-22-19, 10:31 AM
T
Thank you for both for replies.
What if I remove this extra skirting and use some wood filler (trying to match the laminate's color)? Would it look ok?
Old 09-22-19, 10:38 AM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
A floating floor needs room to expand and contract slightly, so no... that would be a bad idea. Your baseboard should be trimmed with base shoe or quarter round.
Old 09-22-19, 11:01 AM
Shadeladie's Avatar
Super Moderator
Received 402 Upvotes on 329 Posts
If it were me, I'd get that contractor back and tell him to send a carpenter to put the quarter round there and remove that awful thing he left you. Why should you have to accept that?
Old 09-23-19, 02:06 AM
T
Well you get what you paid for I guess, he's a friend of a friend who offered to do it cheaper. Now it's been over 2 years, I thought I'd get used to it but it keeps bothering me. Now I got into DIY recently, I decided to revisit this issue and try and see if I can make it look better.
So there's a white base shoe available, exactly same shape and it's a good option except it take eat the same space as now, or maybe an L-shaped white board, something like this but nicer?
Old 09-23-19, 02:21 AM
