Attach decorative wood column to wood floor
Old 02-11-20, 05:02 PM
What is recommended way to attach a decorative wood column to a wood floor? The column will be used to support a granite countertop overhang. The column will be free standing on the floor without any molding covering it. I may have access to the subfloor from the basement Underneath but I havenít checked if itís going to be directly on top of a floor joist.
Old 02-11-20, 07:09 PM
Received 103 Votes on 90 Posts
It can be done several different ways.
https://www.stairwayshop.com/stair-p...od-stairs.html
Old 02-12-20, 02:19 AM
Received 164 Votes on 151 Posts
Need to see the column.
Also what is the floor beneath it?
Old 02-12-20, 04:16 AM
Marq1's Avatar
Received 504 Votes on 467 Posts
Typ there is a base plate attached to the floor, then the column it attached to the base plate but a lot depends if the column is solid/hollow etc!
This is not structural item so no issues with flooring or floor structure!s
