Window sill: round over/Ogee
Received 0 Votes
I have 4 windows that I need to make window sills for. Window sills will be 3/4" thick. round rover edge on top and ogee on bottom. The problem is my router only has a 1/4" shank. I have not been able to find a bit like this shape with 1/2in shank. I don't have much experience with routers. I suppose I could get what I need with separate round over and ogee bits. Is this the right appraoch?
The window sill needs to be > 3.5in wide.
Yes, it will take 2 bits. You would likely do the ogee first and the roundover last. You will probably have the best results if you do the ogee in several passes, getting progressively deeper on each pass until it is as deep as you want it to be.
Received 0 Votes
Thanks everyone. I found out about premade stools last night. I looked at the existing trim on the rest of the windows in my home. Looks like they just used premade and rounded over the top side of the horns on either side. If I had bits, I suppose I could have shaped to horns correctly.
