Biscuit joints
Biscuit joints
Finally got back to my grandson's house to work on his kitchen. I had 4 joints to secure with biscuits BUT I forgot to bring wood glue
so I used liquid nail instead. Should I expect any problems with those joints or will liquid nail be as or almost as good?
I used the waterbased liquid nail but I know it's not as watery as wood glue. I know the biscuit swelling is part of how they work. I'm hoping the liquid nail will be good enough.
Where are the joints? Face frame? What force on the joint? If they are not for a critical structural element (not sure I would use biscuits alone there any way) they should be fine. How big a problem if they fail over time and need to be repaired/replaced? Any way to add to the joint without showing (glue a gusset on the back)?
It's on the face frame, I suppose I could attach wood behind it for added support. It will probably be a couple weeks before I go over there again.
Sounds like it should be OK and you have a solution if it is not.
I watched several YouTube videos last week about fixing "mistakes" in woodworking. Realized that woodworking is not a perfect science and that mistakes can be fixed and still be satisfying.
