Issue with pocket holes-loose joints
Received 0 Votes
I picked up a Kreg jig to join some 3/4 pine boards for a few projects and did a couple tests joins.
I’ve got the jig set to the proper depth and the bit set correctly to 3/4.
After drilling the holes and joining the boards using the recommended coarse 1 1/4 screws the joint feels flimsy, like I could easily pull the joint apart or snap it with very little force. I am clamping the joint before screwing in the screws.
I am planning on gluing the joint for the actual project but I thought that the joint would be more secure for the research that I’ve done.
Should I attempt to sink the holes slightly longer or try 1 1/2” coarse screws? Will these be too long, I don’t have any on hand to try. Or am I doing something wrong?
When you first start your screws, make sure the screw isn't pushing the other piece of wood away as it starts into it. Only other thing it could be is the jig is too far away from the edge as you drill the hole.
Received 0 Votes
There are some tabs on the other side of the jig that are set by the screw depth setting (3/4). I’ve got these tabs up against the board when drilling with the jig clamped to the board.
when I’m joining the boards I’ve got the boards clamped together so I can’t be pushing one board away. I’m stumped.
Received 0 Votes
Upon closer inspection i found some sawdust/small wood chips in the pocket hole which were not letting the screw sink all the way in. I sanded down the inside of the hole and the joints are much better.
