Baseboard trim dilemma
Old 06-08-21, 08:28 PM
B
I am working a project in a room that used to be a garage. The studs were not flush with the inside edge of the sill, so when drywall was hung, the sill edge is proud of it. Looking for trimming tricks for the baseboards. Only thing I can think of is adding some sort of 1X construct flush with the edge of the sill so the baseboard will be flush to the wall. Adding more drywall isn't an option.
Old 06-08-21, 08:49 PM
XSleeper's Avatar
Received 988 Votes on 899 Posts
Post a photo. Hard to give advice sight unseen. We don't know how much its sticking out. Makes a difference, you know.
Old 06-09-21, 05:52 AM
Norm201's Avatar
Received 370 Votes on 335 Posts
What you might do is provide a wide baseboard that has a thickness of 3/4" to 1" (similar to the old fashion 8" high used many years ago). Then on top if that you can add a 1/2 or 1/4 round. Will that cover the void assuming the wallboard tends to even out as you go that high?
