Best Way to Remove Pantry Shelves?
Old 09-05-21, 07:29 AM
T
Received 4 Votes on 3 Posts
I'm replacing existing wood pantry shelves with larger (deeper) ones. I need to determine the best way to remove the existing shelves. I can't tell if they are nailed in or screwed and when I try to hammer them loose from below, they are so tight that they damage the drywall (see photos).
Any ideas? Thanks.
Old 09-05-21, 07:38 AM
Norm201's Avatar
Received 594 Votes on 531 Posts
Cut them down the middle. Then they will wiggle out. I suspect they are painted in. Score the paint line.
Old 09-05-21, 02:45 PM
T
Thanks Norm - will give it a try.
Old 09-05-21, 08:42 PM
Received 2,943 Votes on 2,656 Posts
It looks like there is putty or caulk holding them down at the wall as well as plenty of paint.
You may need to remove that with a knife.
marksr voted this post useful.
Old 09-06-21, 02:55 AM
Received 671 Votes on 594 Posts
Scoring the joint between the shelf and the wall should remove the caulk or paint bond. Might need to do it both on top and the bottom.
Old 09-06-21, 06:56 AM
T
Mark and PJ - thanks!
Old 11-29-21, 06:35 AM
T
Just to close this out - I got around to this project over the weekend. Had to cut down the middle with a recip saw. They were painted in, caulked AND nailed - took a good 2 hours to get them out properly but managed to do so with no damage to the walls - unbelievably.
Thanks all.
