Kitchen cabinet Restriction Hinge Clip
Old 11-21-21, 04:44 PM
R
I understand kitchen cabinet hinges can be adjusted to reduce them from swinging open too far by installing a hinge restriction clip. I trying to determine which hinge restriction clip will work for mine. Unfortunately my soft close hinges do not show the manufacture on them. Attached is a pic of the hinges I have. Does anyone know which hinge restriction clip will work for these? Thank you.
Old 11-21-21, 05:22 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Those look like really cheap generic Chinese hinges like what you might find at a box store (example) and I doubt you will locate an exact match or a matching limiter for them. If a limiter is what you want to use, I would suggest you just change out the hinges for a known brand and get the limiters for those.
Old 11-22-21, 06:11 AM
R
Thanks for your response. I would like to reduce them from swinging open too far, however that can be accomplished. Replacing the hinges is a bit overkill and expensive.
Old 11-22-21, 06:12 AM
XSleeper's Avatar
Put a short chain over 2 short screws.
