Aluminum router fence
Old 01-26-22, 12:04 PM
C
Received 5 Upvotes on 5 Posts
Does anyone know where I can look for an aluminum router fence like this one? Most of the router fence I see is only 3" tall. I need something that is taller...like 6 inches.
Old 01-26-22, 12:29 PM
2
Received 374 Upvotes on 324 Posts
Your photo shows the back of the fence. You can add a higher piece of wood to the front using the T-track that is there with a recessed bolt.
This is a picture of the fence that I made for my router table using a plan found on the internet. You can make the front as high as you want.
File Type: pdf
Charlie2 voted this post useful.
Old 01-26-22, 12:33 PM
P
Received 2,010 Upvotes on 1,802 Posts
You can attach another piece of material to the face of any fence to make it taller. I drilled and tapped a few holes into my aluminum fence. Then my fence extension bolts on with a few flat head screws.
