I left the tape on the stairs too long and the white paint that was used on the risers leaked out onto the wood. I do not want to damage the finish on the steps but Is like to clean the very dried on white paint
Unfortunately some of the paint may have been absorbed into the wood at the edges and the finish does not appear to be a poly or varnish. Worn, oil or wax finish can also absorb paint. If the paint is on top of the wood surface (especially if it is latex) you can probably scrape it off. A small scraper or even a dental pick should work.
I often use the edge of a knife blade to scrape off errant paint. If it's latex paint, denatured alcohol or products like 'goof off' and 'oops' will dissolve the paint - will require elbow grease.
I don't think leaving the tape on too long was the core problem. It looks like the paint wicked underneath the tape. Pressing down the paint edge of tape is very important to seal that edge. There are also special/premium paint masking tapes that seal better when they contact water based paints.
That is why I rarely use tape and when I do I try to remove it as soon as possible. That way if paint seeps under the tape you can remove it easier. Tape tends to give false confidence
Once upon a time, my old house had doors into the kitchen. Years ago the doors were removed and the jams are now covered with many layers of paint. During my kitchen remodel I decided to remove the door stops from the jams for a cleaner look.
The jams will be repainted, but what is the best method to level the paint - wood - paint surface? Removing/replacing and stripping the paint are not options. Sanding has been incredibly slow, even with 60 grit and a ROS. Would joint compound/drywall mud work here? Looking for that secret, light-bulb idea!
Thanks!
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/480x640/kitchen_trim_030522_39b81397e50a83b060c95fe7ad23e48fffe1710c.jpg[/img]
Read More
I just finished building a shed with a gambrel roof and a loft. The shed is 14x20. I am trying to figure out the best way to get stairs to the loft without taking up a ton of space.
I have plans for stairs that fold against the wall, I thought about a set of stairs and connecting them to the loft floor joist with hinges and have a pull rope to pull it up out of the way.
I also have plans for a garage elevator with a hoist that will lift it up and down.
I am soliciting ideas and appreciate and help.
thanksRead More
