Crown Molding- matching
Old 03-14-22, 07:03 PM
I need to recreate this crown molding. The cost to do a custom mold is probably out of my price range. It looks like two pieces of molding...the gap in between the two moldings adds a beautiful depth to the crown molding. Anyone have any suggestions on how I find something similar? Thanks!
Old 03-14-22, 07:19 PM
XSleeper's Avatar
Received 1,532 Votes on 1,376 Posts
Well with no measurements we are just guessing.
Your best bet would be a custom millwork shop. Nothing is going to come close to matching that exactly unless you have knives made, which last time I checked was about $75 per knife.
If you want something close, use a cove crown and alter it, maybe by ripping one side off, adding a filler to the cut side and then adding the part you cut off as a moulding down below that. Or if you can find a plain 4" cove, put a picture rail below it.
Here is one example for starters. https://www.homedepot.com/p/Woodgrai...6983/302785737
The bottom moulding is called picture rail. You can probably locate something close.
Old 03-15-22, 01:26 PM
V
These folks could make it for you. They've run some old stuff for me in the past and should already have knives to do so.
https://www.mouldingsone.com/mouldings/crown/
Old 03-21-22, 06:12 AM
Thanks. I think I found top part...close at least. Struggling with bottom part...thanks for the picture rail advice. Got quoted 350 to build a knife to recreate....nope.
