Nominal vs actual to produce 1 1/4" thickness
Old 03-08-24, 05:04 PM
B
Received 1 Upvote on 1 Post
I'm trying to build out a wall surface 1 1/4" to match preexisting drywall. Is there any combination of actual lumber thickness, that will produce the 1 1/4" or will I have to creatively shim, combining materials?
Old 03-08-24, 05:40 PM
the_tow_guy's Avatar
Received 251 Upvotes on 203 Posts
3/4" + 1/2"
Any 1" dimensional lumber will be 3/4". The 1/2" will be a little trickier, but the big box places carry some 1/2" lumber in red oak and poplar in short sections. You might also be able to combine flat trim molding lumber to get to 1 1/4".
Old 03-08-24, 05:56 PM
B
I'm looking for actual size. I realize that a nominally sized 1 x 3 (actual 3/4" x 2 1/2") is part of the equation, but what dimensional lumber is sized _ x 3 to produce an actual 1/2" x 2 1/2"?
Oops!
I see that you've edited
Old 03-08-24, 06:33 PM
XSleeper's Avatar
Received 1,924 Upvotes on 1,728 Posts
This is why table saws were invented. You would either rip stock 1 1/4" wide from 2x4s or you could use 2 layers of 5/8" ply, ripped 1 1/2" wide to go on top of your studs.
marksr voted this post useful.
Old 03-09-24, 05:03 AM
Could also resaw a 2x4 down to 1 1/4" from the 1 1/2" or even surface plane same, but those are much more involved and depend on your tool inventory. Sleeper's got the best plan.
