lazy susan adjustment
Old 03-31-02, 11:35 AM
harleymon
My lazy susan recently went out of adjustment. The problem is that the stop position is not correct. I cannot find a manufacturer on it. It is a 2 shelf, 3/4 round unit. Mounted in a corner of my kitchen. Can anyone help? Thanks.
Old 04-01-02, 09:18 PM
fewalt's Avatar
harleymon,
Wow, those can be a bugger!
Just adjusted mine a couple weeks ago. I had trouble trying to adjust the shelves on the post so I loosend the center post and twisted it around until it lined up correctly. There should be a set screw on top and on the bottom of the post which need to be loosened. Then you have to twist the post and guess till you get it lined up.
fred
