highlighter stains
Old 05-31-05, 02:52 PM
jacob23
highlighter stains
how do you clean pink highlighter stains off a tan colored wall? or if you just know how to clean highlighter that will work to.
Old 05-31-05, 04:47 PM
T
Rubbing alcohol is usually effective for removing highlighter stains. However, alcohol will remove latex paint. Latex paint tends to be porous and absorbent, so it is likely that the highlighter is not just on the surface. If the stain can not be removed, it should be covered with a couple coats of primer/sealer like Zinnser and repainted.
