Hair color on wood
Old 06-16-05, 12:23 PM
Annette Gregg
Hair color on wood
I spilled some hair color on my bathroom door. How do I get it out?
Old 06-17-05, 12:58 AM
K
L'Oreal Blondissima. Or whatever else you'd use on your own organic fibres to lighten them.
Old 06-18-05, 12:06 PM
T
Hair dye stains tend to be permanent. If bathroom door is painted, you will need to apply a couple coats of primer/sealer and repaint the door. If door is finished wood, you may have some luck lightly sanding the affected area with superfine sandpaper or #0000 steel wool to remove dye stain and then touch up finish.
