removing soot from painted walls
Old 10-10-05, 05:15 PM
shesha
Question removing soot from painted walls
How do you get rid of soot on walls and ceiling? I burn candles in my bathroom frequently and just noticed that the white ceiling has turned grey. I attempted to clean it with ordinary bathroom cleaner, which only made the condition appear worse.
Old 10-10-05, 06:37 PM
Received 672 Votes on 595 Posts
Welcome to the forums
I don't know if there is an effective way to clean soot off of paint. Often the best remedy is to use a primer made for hiding smoke damage and then repaint.
Old 10-10-05, 09:15 PM
T
Received 1 Vote on 1 Post
A special sponge for removing soot from walls is called a dry sponge. It works like a giant eraser. The sponge is used dry. When attempting to clean soot of walls with water-based cleaners it's like mixing water and oil and compounds cleaning problems. Use degreaser or TSP (tri-sodium phosphate) to clean walls, prime to seal to prevent bleed through, and paint. Use high quality smokeless candles.
Old 10-11-05, 07:29 AM
Received 1,165 Votes on 1,123 Posts
Because of this problem, we do not let tenants have any open flames in their units, be it candles or cigarettes. We can always tell if they broke that rule.
Old 10-11-05, 07:35 AM
Docduck's Avatar
I think i know were tweleve is going with this. Sounds like using a microfiber pad/sponge will do the trick. If not paint over it with a stain blocker..primer. Most of the time you will have to do this to get rid of the smell anyways,.
Old 10-21-05, 07:10 PM
Laurie8801
Hi Shesha - I had the same problem in an apartment I lived in. I used Mr. Clean Magic Erasers which worked like a charm on white semi-gloss paint. If you try it, you should do a test area to see if it will take your paint off first before using it - I used it on white flat paint and it took some of the paint off the wall. Good luck! Laurie
