Candle wax on wood furniture
Old 01-26-06, 02:54 AM
Post Candle wax on wood furniture
Help!
A packet of citronella candles were left on our jarrah outdoor setting. In the heat, they have completely melted and it has absorbed into the wood.
How do we remove it???
Old 01-31-06, 01:12 AM
Docduck's Avatar
You may want to try taking a wet rag sit over the area..then using a steam iron on the medium setting. Set on the rag and move over the area 30 secs at a time. Be careful not to burn the wood or yourself. It should melt the wax and pull it into the rag. If not i would clean the area best you can with a solvent and restain. Not going to match but that would be the only thing left.
Old 01-31-06, 01:06 PM
Received 94 Votes on 83 Posts
Once clean, sealing the wood will prevent this from happening again.
Old 02-06-06, 08:57 PM
T
Water on wax will be ineffective because wax repels water. Scrape away excess and use the warm iron method for trying to lift wax out of wood. It is not likely that you will have much success as the hot wax has been absorbed deep into wood fibers. Attempts to apply surface finish will encounter adhesion problems in areas where wood received wax.
