vacuum insulation dust?
Received 0 Votes
Hello,
I'm planning a home improvement project that will result in some insulation dust inside the home. The home is just three year's old. I will use drop cloths and wear a mask during the project, but I expect to vacuum some dust. Do I need a special vacuum for the dust? one with a HEPA filter?
Thanks
Thanks
you know what I did... I used my shop vacuum, set it near a door and put a large vacuum hose on the exhaust going to a piece of pipe outside.. you could also, just set the vacuum outside and use a long vacuum hose inside.. it just lets it exhaust outside and away from the interior of your home..
