moss on stucco
moss on stucco
I have stucco walls (the newer sprayed-on kind, not the original trowelled-on kind). In some shady spots I have moss (I assume - it's green).
I have a pressure washer, but I'm afraid it may be too harsh.
I have a pump sprayer in which I'd use a mild bleach solution, but I'm afraid any bleach might be too harsh.
Any suggestions on removing the moss?
diluted bleach should be ok for it...use a deck brush...spray on the bleach let sit 10-15 mins if you can keep it wet...brush..hose it off...if it peels off...than the paint didnt have good adhesion to begin with
