(Cleaning) Oven door stains
Old 04-28-06, 09:01 AM
neverstop
I have a white enamel oven door which has two brown stains on the top. Any suggestions as to how I can remove the stains? Also I noticed that the glass on the oven door has a couple of small stains on the inside of the glass. Is there any way to remove them? Thanks
Old 04-28-06, 08:09 PM
T
Received 2 Upvotes on 2 Posts
If stains on edge of oven door are not permanent due to heat discoloration, you should be able to remove them with mildly abrasive cleaner or degreaser product. #0000 superfine steel wool tends to dry buff away such stains on baked on enamel without any surface damage. Stains between glass on oven door will require removing and dismantling oven door to access interior of glass for cleaning.
Old 04-29-06, 06:25 AM
neverstop
Oven Stains
Thanks so very much
