ink pen exploded in my dryer
Received 0 Votes
high dry heat can set stains...so im thinking the clothes are a lost cause
the drum you can try rubbing alcohol and let it sit on them...just spin the drum around and work on the bottom area and spin and repeat...but im willing to guess the heat has also set the ink into the pain
may be forced to either let it go OR recoat with a primer paint that is going to be heat resistant and will not chip
Received 0 Votes
Wipe dryer drum with white rag and cleaning solvent like rubbing alcohol. Change rag as needed. Never pour cleaner directly into dryer drum. Continue to wipe until no more ink comes off. To assure all ink has been removed, run a couple old towels through a cycle. Any discoloration to drum will not interfere with operation of dryer. The key is not have ink come off on laundry.
Whether or not laundry is a lost cause will depend on the extent of staining and severity. Stains if heated often become next to impossible to remove. You can try blotting stains from outside toward middle with white rag and solvent cleaner to see if you have any success. Continue to blot if having success until stain is gone. Then wash in hottest water appropriate for fabric and all fabric bleach.
Received 0 Votes
Received 0 Votes
Ink may stain dryer drum. Wiping off ink with rag and rubbing alcohol until no more comes off and running a cycle with a couple old towels assures that ink getting on laundry will not be a problem. Residual stains in dryer drum pose no laundry problems and do not affect the functioning of the dryer.
Received 0 Votes
removing ink from dryer drum
I used a mr. clean magic eraser, and a mixture of some bon ami powder and 70% isopropol alchohol on the magic eraser with a good degree of success! I mostly wanted to prevent transfer of ink to future loads of clothing. I am going to assume the ink on the clothes in the original dryer load is toast... ah well, keep that pen in my ear from now on.
