Cleaning Rubber off Wool carpet
Old 07-31-06, 02:46 PM
T
Over the weekend I had parents stay over and I warned them not to blow up the inflatable bed in the back room (cream wool carpet.) They went ahead and did so and the result is some dirty rubber marks where the pump was used.
Any ideas?
Thanks
Old 07-31-06, 03:24 PM
T
Received 1 Upvote on 1 Post
Blot with white rag and solvent cleaner like rubbing alcohol, denatured alcohol, or dry cleaning solvent. Apply cleaner to rage and blot from outside stain toward middle to prevent spreading. Do not rub carpet fibers. Blot. Continue to blot until stains are removed.
Old 07-31-06, 10:22 PM
Docduck's Avatar
agree with twelvepole....stick to the alcohol
avoid using any high pH chemicals and oxidizers....they will damage or destroy the wool...dont be afraid if the wool gives off a odd smell if wet...thats just how wool is
Old 08-01-06, 11:46 AM
T
do you have any names of products?
thanks for the quick replies
Old 08-01-06, 12:15 PM
Received 1,231 Upvotes on 1,179 Posts
Regular rubbing alcohol from the drugstore is fine.
Old 08-02-06, 10:45 PM
Docduck's Avatar
try to stay away from spray and wash type products for wool as well.
