How to remove rubber stain on Finished Bar
Old 08-20-06, 01:12 PM
B
I placed a rubber mat on a finished ash wood bar and have a huge black rubber stain on a blond ash wood bar. Is there a way to clean it or does the top need to completely refinished
Old 08-20-06, 01:47 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Depending on how tough the final finish is, you may want to try Methyl Ethyl Keytone (MEK). It has a high flash point and does good as a general cleaner without the harshness of Laquer thinner or the like. You have little to lose, so I would try it on a small area. If the finish is clear, it may tend to fog the finish, but it can be buffed out with wax.
Old 08-23-06, 09:43 AM
B
Is MEK the product name? I tested goof off and it removed the stain but took off some of the finish
Thx
Old 08-26-06, 03:51 PM
T
Received 1 Upvote on 1 Post
Always test any DIY method in inconspicuous place first. If finish is lacquer, mineral spirits can be used. If finish is polyurethane, acetone can be used. If finish was removed, to restore it will require lightly sanding and reapplication of same type of finish.
