Window Cleaning
Old 09-04-06, 02:37 PM
dottiealves's Avatar
Location: Canyon Lake near San Antonio or New Braunfels
Smile Window Cleaning
I live high on a hill and have large windows all aroung the house, part of the windows are very hard to reach as the hill falls away near the base of the wall. Is there a way to spray a product or mixture to clean the windows without wiping with cloth or sqeegee? We live in a hard water area. Thanks, Dottie
Old 09-05-06, 07:07 AM
Docduck's Avatar
I would go with a 50/50 vinegar and water mixture. And i would buy a extension pole with the scrubber and squegee...mix your solution up in a wide mouth bucket..dunk your scrubber..use your extension pole then squegee down
vinegar should help with the hard water
Old 09-05-06, 07:17 AM
Received 1,273 Upvotes on 1,213 Posts
Windex also makes a product that attached to the end of your garden hose and sprays onto the windows. I believe docduck's suggestion will give you better results, but the windex spray is easier.
