Nail polish in the car??
Old 09-04-06, 04:30 PM
Micahru's Avatar
Unhappy Nail polish in the car??
Hi there,
I have a problem, in my truck, there was some clear nail polish, that spilt on the leather seat. does anyone know how to get off without hurting the leather in any way?
Old 09-04-06, 04:51 PM
D
Received 2 Upvotes on 2 Posts
Here's a previous thread I think will help you:
http://forum.doityourself.com/showthread.php?t=217773&highlight=nail+polish+leather
It states:
"Anything that is going to remove the nail polish is most likely going to damage the leather itself. There are many different types and finishes of leather. Professional leather products are your best bet. I have removed nail polish from leather ( in a slow process i might add) by using reccomended leather soap and slow gentle pressure. But in your case you may want to search for leather cleaners or contact a professional."
by Docduck
and...
"There are many types of leathers, finishes, and dyes, so most leather manufacturers recommend professional leather cleaning. As indicated, anything strong enough to remove the nail polish will likely affect the upholstery. You can try non-acetone (banana oil) nail polish remover. Test first in inconspicuous place for ill effects. Blot with white rag from outside stain toward middle to remove nail polish. Once nail polish is removed, you will likely have an oily stain from the banana oil. Rub cornstarch into stain. Rub briskly with hand to heat up leather so it will release oil into cornstarch. Repeat as necessary. Any remaining oily residue will like be absorbed into leather and disappear over time. If in doubt, call a professional leather cleaner."
by twelvepole.
Hope this helps. BTW: I like your avatar!
Old 09-04-06, 05:50 PM
Micahru's Avatar
Why.... thank you...
Well thank you very much. it did indeed help.
And yes... i like your avatar also ^^
AND...
i Love your signature!!
