Rust removal
Old 10-12-06, 10:38 AM
Rust removal
How would I go about cleaning rust off of Metal rocking chair springs
Old 10-12-06, 11:05 AM
Received 44 Votes on 41 Posts
Naval jelly works well, but can be a little nasty. Otherwise, WD40, a scrub pad and some elbow grease will usually work.
Old 10-12-06, 11:30 AM
Is it a Myth that Coke works?
Old 10-12-06, 12:06 PM
The Coca Cola Company claims that it is a myth that its soft drink can be used for all purposes for which it is acclaimed. http://www2.coca-cola.com/contactus/myths_rumors/packaging_cleaner.html
Coke contains phosphoric acid and will remove slight amounts of rust. The point is that there are better things for removing rust.
Drink the Coke and use WD-40 and 400 grit wet/dry sandpaper. The advantage of WD-40 is that it fills pores and rust with a noncorrosive substance and prevents additional rusting. Then apply several coats of paste wax to control rust formation in the future.
Old 10-12-06, 12:24 PM
Docduck's Avatar
wd-40 sounds like the way to go..i would then tape off any areas you dont want primed and hit it with a spray can of a rustoleum type product...i wouldnt take the springs off...if they are old they may pop or you may have a hard time getting them back into shape
Old 10-12-06, 12:41 PM
the_tow_guy's Avatar
Received 26 Votes on 23 Posts
If it's just light rust and not flaking off, hit it with a rust conversion product and then topcoat or leave it as is; the rust conversion product will turn essentially a black color.
Old 10-15-06, 10:33 PM
Well I took my chances with the Coke just for ha ha's and guess what...................IT WORKED AWESOME!!!! 10 Years of caked on rust gone after 24 hours of soaking in Coke
Old 10-16-06, 12:48 AM
Docduck's Avatar
make sure you top coat or seal the springs in some way..now that you have that rust off..to prevent further issues
Old 10-17-06, 09:51 PM
I doubt that spraying Rustoleum or any type of primer on metal that has been coated with WD-40 will do any good.
It'd be like spray painting to bottom of a skillet that you had just sprayed with PAM.
The Rustoleum or primer will not adhere to a lubricated surface.
