Cleaning Laminate Flooring
Old 02-08-07, 12:23 PM
Could you tell me if there is anything other than vinegar to clean floors with. I have spotting and streaking after I mop.
Old 02-08-07, 02:54 PM
D
Try using a dry towel or cloth instead of the mop and a spray bottle for the vinegar/water solution.
Old 02-08-07, 03:00 PM
T
Mop should be squeezed nearly dry. Clean a section at a time. Toss down an old towel and rub back and forth to dry and prevent streaking and spotting before moving on to the next section.
Old 02-10-07, 04:34 PM
Docduck's Avatar
make sure your dry sweep the floor first...sounds like either the mop is too wet or floor is just too dirty
vinegar/water mix is the best "home remedy" for these type of floors
