What's the BEST way to remove musty odor from the INSIDE of Antique Furniture
Old 03-06-07, 07:18 AM
jdegeorge's Avatar
I have an antique dresser that's in very good shape on the outside. Although there is no visible mold nor any signs of water damage on the inside, there is a strong musty odor.
I've searched through the forums and found several suggestions on how to remove the odor from the inside by using Murphy's Oil Soap, or a mixture of bleach/detergent/water, sealing the inside with varnish, etc.
From reading all these suggestions, I haven't been able to determine if there's a consensus on this. Is there?
Please let me know when you can.
Thanks everyone!
Old 03-06-07, 08:19 AM
If musty odor is caused by mold/mildew, all surfaces inside the cabinet box and inside and outside of drawers will have to be cleaned. Bleach/water solution is effective for killing mold/mildew. Wiping with denatured alcohol is also effective. After cleaning, if odor persists, all surfaces inside the cabinet box and inside/outside drawer boxes can be sealed to seal in odors.
Old 03-06-07, 08:39 AM
jdegeorge's Avatar
Thanks, twelvepole! I'll clean and then seal if necessary.
