How to remove (deep) scratch on stainless steel wall hood
Received 0 Votes
My kitchen wall hood has a deep vertical scratch right in the front of the chimney casing. How can I remove it? I read that Bar Keepers Friend (sp?) is for cosmetic, minor scratches, and that rubbing/polish compound (auto body kind) and some wet 600 grit paper could work. I can easily access up to 1500 grit sandpaper.
Thanks
Thanks
Received 0 Votes
Deep scratches are impossible to remove from stainless. For smooth stainless, even minor scratches tend to be impossible to remove. Some report success with Home Depot's Scratch B Gone. Any attempts to repair scratch, make sure you rub along grain if you have a brushed finish.
