mildew and smell
mildew and smell
i have an older building that had a small business in it for many years with no problems. now the business is closed and we did get water in on the carpet. then the problem started. we removed the carpet down to the cement floor but the mold and smell are still there. is there a spray or something i can use to kill this problem? thanks
Saturate concrete floor with enzyme digester cleaner. The enzymes will need time to digest the odor causing bacteria in the porous concrete. Keep floor wet with cleaner. Enzyme cleaner/deodorizers are marketed under a variety of names such as Out, OdoBan, Nature's Miracle, and others. Once satisfied that the odor is under control, use dehumidifier and fans to expedite drying of concrete floor.
Using enzyme digester cleaner is much safer than using the 1 part bleach to 4 parts water that many recommend. Bleach is smelly and may affect respiratory system. Bleach is not a EPA registered fungicide. There are commercial fungicides available.
In structures that have been closed up, there is no humidity control. Mold and mildew can be problems if humidity level is above 60%. Running HVAC system year round helps to control humidity levels. Where humidity is above 35-55%, a dehumifier will lower humidity levels. Fans will improve air circulation.
Heres the golden question of all...twelevepole has it right on.. BUT did the drywall or walls get moisture in them?? If so drywall would of sucked up the water from the carpet into the lower part of the drywall and studs. If so remove the baseboard carefully and inspect for mold...wear gloves and mask..protect yourself... If mold is present you may want to first contact your homeowners ins...and the bus owners...if its older damage someone may still be liable for cleanup costs
DONT underestimate water damage....the cost of materials, mold remidation and replacement of effected materials + labor could run into thousands. If left unrepaired the medical and health risks are high..not to mention if/when you sell the property you will then be liable for repairs if it is seen.
When in doubt call a professional restoration company...but check with insurance first...most do cover some forms of water damage
