candle wax spilled
Received 0 Votes
Hi and welcome to the forum! I'm not sure if there's a special way or not, but have you tried using a scrapper or putty knife or something similar and just scrape it off? Seems it should work.
Since you will be painting anyway...I think scraping would probably be best, followed by sanding to blend any marks. I have taken a paper towel soaked in Goof Off and applied it to wax with constant pressure and then removed it just as it was almost dry..but that will probably take longer and do more damage to the paint in the long run.
