how do i remove dry erase marker from vinyl siding
Old 06-25-09, 11:16 AM
my 5 yr old niece wrote in dry erase marker on our vinyl siding and have tried several things to remove it but they did not work need help!!!
Old 06-25-09, 04:42 PM
Received 98 Votes on 86 Posts
Rubbing alcohol is the best solvent for ink. If this area gets direct sunlight on it, you'll have more difficulty removing the ink.
Old 06-26-09, 06:02 AM
the_tow_guy's Avatar
Received 66 Votes on 55 Posts
Could try WD-40, too. It sometimes does surprising things.
Old 06-26-09, 03:52 PM
N
Received 1 Vote on 1 Post
Mr. Clean Magic Eraser worked wonders on vinyl siding. We used it to help remove fence stain all over our house and garage when people were sloppy. Takes elbow grease and a bit of water, but it works and didn't damage the siding. Since it's spongy, it had no problem getting into the fine texture on our siding.
