Leaving lights on all day to stop mould
Hi fanman, molds thrive on moisture and a food source. The food source can be any organic material, even the paper on your sheetrock or your homes wood framing. In bathroors it is recommenred that you run the exhaust fan for 20 minutes after showers. Correct all leaks and check your basement for moisture. A dirt floor in a basement or crawl space needs to be covered and sealed with a vapor barrier. Without specifics as to what your problem is, this is the best I can do.
lights out
Bud
lights out
Bud
