dried dog vomit on ribbed courdiroy microfiber!
Received 0 Votes
my dog must have thrown up on my couch yesterday as I just noticed it and it is completely dry (and crusty). there is no odor - but I am worried that this will leave a stain. any recomendations on what i should use and how to apply? thanks!!
gently scrape off what you can and vaccum up...check the manufactors suggestions....the only microfibers that i have seen that bleed color when wet are the reds and blues....after you scrape off what you can just use plain water for now and see what thats does..apply with a spray bottle and blot with a white rag and allow to dry...no stain or smell..it sounds like it wasnt enough to soak in
if there is something left...try a enzyme based product...pet stores usually have them...apply and let sit 10-15 mins then repeat the above method using the water to remove the cleaner....ALWAYS test any cleaning method on the test panel under the cushions or the back skirt
