ink in gas dryer
Old 09-22-09, 07:11 AM
ink in gas dryer
Hello My husband had an ink pen in his work shirt and it went into the dryer and now there is ink all inside the dryer drum what can I use to get it out that is not flammable because it is a gas dryer.
Old 09-22-09, 02:12 PM
Docduck's Avatar
you can search the forums..i think some of the members have had the same problem in the past. A goof off type cleaner and some patience may work. Most of the time it is baked into the paint. If that is the case they do make applicane paint that is safe and should hold up well to heat.
