Carpet stain
Old 01-16-10, 01:06 PM
I
Carpet stain
Hi,
Yesterday, I dropped a bit of tomato sauce on the beige carpet. I tried to clean it right away with Bicarbonate of Soda - that is, I sprinkled bicarbonate on the stains then rubbed with a wet towel. The stains are gone, but now there's a white stain due to the bicarbonate. Perhaps I used too much bicarbonate?
Could you tell me if there is something I could do to remove the stain?
Thanks a lot in advance!
Aurélie
Old 01-18-10, 10:22 PM
Docduck's Avatar
take a white rag and gently blot it and use cool plain water to rinse it..after you worked it the best you can. Set a few dry rags and put a plastic bucket with some sand or other heavy object in it
Old 01-19-10, 02:24 PM
Received 1,233 Upvotes on 1,181 Posts
Docduck's idea works but I don't have as much patience as he does. I would spray the area with clean water, work it in with a brush and then hit it with a wet/dry vac, repeating until the stain is gone.
Old 01-20-10, 01:52 PM
I
Thanks a lot to both of you! I'm going to try your ideas and keep you posted :-)
