How to clean grease from the very top of cabinets?
I have tried several products to clean the top of my cabinets of the "grease" build up of cooking. I clean them at least every 6 months. The products I use work ok but lots of "elbow" grease. Is there something that would cut the grease with out all the extra scrubbing?? I am willing to try anything! Thanks.
Welcome to the forums
Scrubing more often would be my first thought, don't let the grease sit and harden for a long time.
Do you have a vent that exits to the outdoors or do you have a recirculating vent? A vent to the outdoors will exit most cooking odors & grease. If a recirculting vent, then every 6 mos. is not frequent enough for cleaning. Depending on type of vent, likely recirculating in your case, because of frequent complaints, you can either reduce the frying
