cleaning alum siding
Old 03-28-12, 06:32 PM
my house has alum siding and is oxidzed pretty bad what is the best cleaner i should get to use with my pressure washer.
Old 03-29-12, 04:07 AM
GregH's Avatar
Super Moderator
Received 53 Votes on 49 Posts
You can buy a siding cleaner made for pressure washers except that it would be very easy to damage the finish if not careful.
I would recommend that you use a siding cleaner, a fine bristle car wash brush a garden hose and do it by hand.
You could go from oxidized to a damaged finish in no time if it doesn't go well.
Old 03-29-12, 04:17 AM
Received 404 Votes on 360 Posts
How old is the siding? what are your plans for it once it's clean?
As Greg noted it can be very easy to remove enough of the existing finish to make it look bad. Also a PWer can force water where it shouldn't go if you spray at the wrong angle. Aluminum siding can be painted [with the proper prep] if needed.
