Is it possible to get glue off quartz counter top
Received 0 Votes
I was using super glue on something and the object fell on the counter and I grabbed it, but a bit got on my quartz counter top. I wiped it ASAP but it left streaks. You can only see it from a certain view. It looks like it ate the counter top and now I'm stuck with the streaks. I now have taken that horrid stuff down in the workshop. My husband is the one who kept it in the kitchen but I can't tell him why I took it to his work shop.
Received 0 Votes
Acetone should remove it. Use a white paper towel to rub it around, then wipe dry. If there's any build up of the glue on the countertop, remove it first with a single edge razorblade. Very fine steel wool can help also. Good luck
