Cleaning grease from range hood?
I have a great range hood with little plastic grease cups. The trouble is that the grease is so concentrated it's like tar. Dawn for dishes won't dissolve it, nor will Greased Lightning spray. I've run them through the dishwasher but then my dishes get sticky. Any tips?
Have you physically removed as much as you can, like with a knife or scraper or screwdriver?
After that, I'd try some mineral spirits but keep an eye on it, as it can affect some plastics.
So far the most effective thing I've found is a strong ammonia solution made with boiling water. I'm lining the cups with plastic wrap for a "peel and toss" process next time!
While I'm not sure what plastic grease cups are, I would think if they're subjected to heat, the plastic wrap will melt and stick to the cups and will not be easy to remove. I'd think non stick tinfoil might be a better idea.?
[ATTACH=CONFIG]57691[/ATTACH]
I have more faith in plastic wrap. Check out THIS RECIPE for ribs baked in plastic wrap at 225°!
I soak parts in a strong Greased Lightning or Purple Power solution. Because of the strength you must wear rubber gloves. But between the soaking and repeated scrubbing the grease will come off. You just keep wearing it down and take it off layer by layer until it's gone.
